rk911 wrote:
et2 wrote:
...As others mentioned the jeeps have to have the correct transmission ( active drive II I believe). We now own the Grand Cherokee overland. Tows great.
I wouldn't worry what Jeep calls their transmissions...names can easily be confused. just make sure that the transfer case has a manually selectable neutral position. "make sure" means having the sales critter demonstrate that for me and then follow-up by checking the user manual section for 'Recreational Towing'.
By manual, it is a little bitty button that you push with a pen. I would definitely make sure I knew the name of the transfer case and if it is flat tow-able.
Jeep Clicky
