- Johno02ExplorerWe usually keep several boxes of a brand name mouse bait at several locations in and around the Motor home when it is not in use. Check them as often as possible, looking for any signs of use. If you find any being used, look for other signs of the source and try to fix or seal them.
- Dennis12ExplorerI see a new item called Rodent Sheriff. Good and bad reviews ??? Next try buying 6 cats, may need more if you run out of mice.
- EV2Explorer
Tkotis5 wrote:
We are renting a storage unit for are new motor home how do you keep mice from getting in your rv some one told me fabric sheets and then read to put Irish spring soap open in the rv not sure what to do
You might try a search for the hundreds of past threads posted on this topic with every possible solution known to man. The only sure method is to seal EVERY possible opening. - donn0128Explorer IITried em all best solution is to prevent entey. Home Depot sells rhodent proof spray foam. Buy a couple cans and spend a day sealing everything you can find. On larger openings add steel wool first. Then buy a bunch of sticky traps, add a small dab of peanut butter. You will then have done everything you can.
- usersmanualExplorer
I have used moth balls and there very effective.also theres a product called cab fresh that works great but expensive
If its plugged in the electric plug ins also help a lot
Forgot to say and will add as others have opined here
remove ALL foods including dry dog and cat food. they love animal dry food.I also put mouse poison in containers under the MH
38,763 PostsLatest Activity: Dec 05, 2025
