Bumpyroad
Aug 22, 2014Explorer
mlts22 wrote:
If I had to reduce my must-haves from my relatively long list to a few, it would be a fiberglass or metal roof, Azdel sides, E-450/V10 chassis, and an onboard genset.
a better list IMHO
One thing I'm curious about... are heat pumps that better than a conventional A/C unit with a heat strip? Below 40 degrees, heat pumps stop working, but a heat strip may not be as effective as a Vornado space heater (or similar), but would definitely help supplement the furnace.
a $20 ceramic cube heater will do a better job than the heat strip in the AC. do you really want to wear out your AC fan for this ineffectual heat source? and I have been in campgrounds where they charge extra for electric heat. sort of obvious when your AC is humming at 10 degrees outside.
bumpy
38,774 PostsLatest Activity: Apr 26, 2026
