Effy
Jul 29, 2015Explorer II
m188265 wrote:
Wolfe10, it is only while driving. Plugged into shore power or with the generator running it is fine. While driving, with only the refidgerator running the coach batteries run down. The biggest headache is, once the battery voltage goes below 9.5, the relays won't kick in to enable shore power, so you have to charge the batteries before you can get any power.
Sounds like your engine alternator isn't charging the batts. I suspect the BCC. Had issues with that on my 29.1. Same symptoms
