sssooo's avatar
sssooo
what is it
I have a 2018 Fleetwood Bounder 36H that has a rocker switch behind the sliding door above the passenger seat don't have any idea what it does?
Click For Full-Size Image.
I also have a HDMI cable that is behind the DVD player that I cant get it to do anything? I hooked it to the dvd player it didn't show up anywhere?
  • That switch is used for the ceiling lights, when the bed above the captains chairs is in the down position. So the person sleeping up there does not have to get down to shut off the lights.
  • Ok the lite does not turn on when pushed?the switch does not stay pushed in when pushed it springs back to the same position it just rocks back to original position
    It’s not tv booster
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Well two good guesses up there
    1: OTA antenna amplifier.. If you do not have either a matrix switch (Box of many buttons) with a POWER button. or a wall plate with teh 12 volt outlet, antenna connection, switch and light. or a Sensar Pro. that's a good chance.
    2: Satellite antenna (rooftop dome) you will have a Dome up there.
    The lack of "Winegard" on the switch suggests a dome.
  • I'm guessing it's for the satellite. If you turn the switch on you should hear the satellite move.
38,778 PostsLatest Activity: Jun 07, 2026
