Shadow_Catcher
Apr 06, 2014Explorer
IF your RV was assembled correctly 65 PSI should be good, if not... You can do a leak test using air. I use the plug I use for blowing out the water lines and pump up the system for a leak down test. If I lose pressure I start looking for leaks using soapy water (beats having water spray all over the place). I also check for gas leaks at the same time, and easier to do, turn on the gas and turn it off if you come back the next day and turn it on and get a substantial flow back up to pressure you have a leak.
38,777 PostsLatest Activity: May 24, 2026
