- Executive45Explorer IIII was always taught not to bypass anything that I wasn't absolutely, positively sure nothing bad would happen if I bypassed it. I'm also sure the cost of the valve, assuming it's the BTFV, will cost no more than the fitting necessary to bypass it...Dennis
- DrewEExplorer III
wildmanbaker wrote:
gutfelt wrote:
dougrainer wrote:
gutfelt wrote:
as I was also and now u see why u need a 90 degree 1/2X1/2 connecter to bypass this unneeded valve
Why is it unneeded??? Doug
ok I think u know what a I mean your not dumb so I ask why is it really required? I know exactly what its for and for the most part I thinks it code to have one but I don't believe its at all necessary
in a MH
Really? You a have been around long enough to know that if something can go wrong, it will. The last thing you want is to have the spray nozzle hang open after flushing the empty tank, and not knowing it, and finding out as your black tank fills. Remember the movie "RV"?
The anti-siphon valve will not prevent that.
What it does prevent is the drawing of water from the black tank into the potable water system should that be under negative pressure for some reason. One way that could happen is if the water pump were off and the city water connection off (so no pressure) and the tank flush valve left open and the outside shower were on and at a lower position than the black tank. It would siphon water etc. from the black tank into the potable water supply system. This may sound like a contrived situation, and perhaps it is, but it's certainly not beyond the realm of something that could happen to a slightly forgetful or distracted person.
It should be clear why the plumbing codes require devices or designs to prevent this sort of cross-contamination. (It's also why sinks and bathtubs generally need to have the spigots set above the flood level of the basin, and why toilet tank fill valves have anti-siphon valves built in, etc.) - wildmanbakerExplorer
in a MH
Really? You a have been around long enough to know that if something can go wrong, it will. The last thing you want is to have the spray nozzle hang open after flushing the empty tank, and not knowing it, and finding out as your black tank fills. Remember the movie "RV"? - gutfeltExplorer
in a MH - 2oldmanExplorer IIA picture would be of immense help.
Why is it unneeded??? Doug- gutfeltExploreras I was also and now u see why u need a 90 degree 1/2X1/2 connecter to bypass this unneeded valve
- Old-BiscuitExplorer IIII think DOUG is CORRECT......
Black Tank Flush 'anti-siphon vacuum breaker backflow preventer valve'
- wlstroudExplorerIt may be an expansion tank with an air valve for pressurizing the in-tank bladder. Helps eliminate surging and maintains a more constant waterline pressure.
- gutfeltExplorer
rodjburge wrote:
In my 1999 Endeavor, I have a minor water leak. During the process of tracking down the leak I found a valve looking object that is in line to the hot water line and mounted underneath my bath room sink above the hot water tank. It is mounted higher than the tank so I think it is an air valve that allows the line to drain properly. Am I correct??
most likely as said here already the black tank flush anti back drain valve those things are bad for leaking just use a 90 degree 1/2 by 1/2 line joiner and eliminate it
38,766 PostsLatest Activity: Jan 10, 2026
