GaryKH
Apr 18, 2017Explorer
arm wrote:
The filter treads into the fresh water tank at the very bottom/side and the drain line threads onto the filter housing. Your fresh water fill tees into the drain line so it back fills the tank and it is only a screen filter. The clear plastic cover screws off to clean the screen. It is best replaced on a hoist if you can use one, but I have replaced them with wheel ramps, but laying on the ground is not my thing any more. This location is for 1994 to 1998 roadtrek's, on the Dodge chassis, that I have personally changed, and location may vary for other models, but the two different filters on the shelf were for a number of different years and models.
Good luck.
Thanks for this. I had always assumed that was the line going up to the pump, not coming in from the city fill. Where is the line that goes to the pump then? Is it inside the tank?
38,779 PostsLatest Activity: Jun 16, 2026
