gerrym51
Sep 05, 2014Explorer II
as obgraham says-technically it is a high amp alternator-however it's more of a system
the 'total' E-trek is 8 6 volt batterie/engine generator/6000 watt inverter charger-solar panels-plus the special wiring for all that power(about 50 amps).
the 'partial e-trek' is 4 6 volt batteries/3000 watt inverter/charger/solar panels and the special wiring.
although roadtrek says minimum 2500 watt inverter or minimum 5000 watt inverter in the recent past they are actually using 3000 and 6000 respectivley
38,782 PostsLatest Activity: Sep 10, 2026
