olfarmer
Jan 09, 2014Explorer II
I don't know but 210 to 215 on normal roads sounds a little too hot to me. If it is actually running that hot I would consider a larger external cooler, especially if you are going to tow. You might ask a mechanic whether those temps are too hot. I would at least change the fluid fairly often as I believe the fluid breaks down faster at high temps. Does the fluid have a smell or look brown? It should be bright red and not smell burned. You have a pretty heavy rig for a gas motorhome.
38,777 PostsLatest Activity: May 20, 2026
