- MrWizardModeratorI will recommend the scan gauge for him
I know he doesn't want to go the pc route with silver leaf
And his Serrano really doesn't have an easy use mounting spot, for driver use with a notebook or pc.And he doesn't want that..Already been suggested and turned down - Pass42ExplorerI picked up a netbook (small laptop), an Aspire One, used.... and I use the silverleaf program.....Excellent info & data about what is actually being seen by your engine's computer... real time, real info, real accurate.......
- mike_brezExplorerI like the ScanGuage just because it has it's own small screen. I really don't want a small laptop sitting up front. First of I don't own one and second I have no were to put it in the driving area.
- superkExplorerNah they are there, you most likely just havent found them yet ;)
Sometimes there is a cover over the port, check (usually) lower left of the steering wheel. - MrWizardModeratorNope NO plugs on my 95
I think first appeared with 96 - jplante4Explorer II
MrWizard wrote:
Nice to know there IS a plug in my Safari
but i know my relative is NOT interested in connecting a PC..I already suggested the Silver leaf
he just wants something he can use,(plugin if-when there is a problem) for trouble shooting codes, then write them down to give to the shop
ScanGuage has that too. - MrWizardModeratorNice to know there IS a plug in my Safari
he just wants something he can use,(plugin if-when there is a problem) for trouble shooting codes, then write them down to give to the shop - sailor_louExplorerAnother thumbs up for Silverleaf VMSpc.
Lou
05 Travel Supreme Envoy - jplante4Explorer IIYour 95 Safari should have a J1708 6 pin diag tap under the dash near the steering wheel and a second one in the engine service bay.
You can get a ScanGuage D to plug into these.
http://www.scangauge.com/products/scangauged/ - bluwtr49Explorer III concur on the Silverleaf...best available technology without questions. Call them and ask what it would take to do the interface.
38,778 PostsLatest Activity: Jun 06, 2026
