Mile_High
Sep 22, 2018Explorer
Bruce Brown wrote:Definately a leak problem after the roof blows off or peels back, I agree :) :)Mile High wrote:
It's not a leak issue, but I'll argue with Bruce on that until I pass this planet :) It actually can't leak through there if the weep holes below are clear. The seal is a mechanical adhesion issue that keeps the roof flap sealed to the awning rail. If it is allowed to come loose, the wind can get under it and it will peel your roof back.
I you can push back on the fiberglass and it separates away from the awning rail, the sealant has failed and needs to be replaced. The sealant adhears the the fiberglass flap to the awning rail as shown in the diagram. There is no sealant behind that flap.
Our friends was a 2000 Adventurer. Didn't you say Winnie had changed the design a few years back to the current way? I honestly don't remember, but it seems I read that somewhere? Then again I'm old, so the memory isn't what it once was! :B
And on a side note, if the roof peels back I'm pretty sure it would create a leakage issue. :B :B
I visited the factory this year and as it was explained to me, that wall to roof interlock and roof cove seal has been used for better than 50 years on all models. If the roof gets cut short or sloppy, it can be an issue and that may have contributed to some model years that had some consistent problems, but regardless, if it gets neglected it will ruin your day in a cross wind.
2018 was the first year they have ever used a rubber roof as I saw on the production line, on their entry level Intent Class A and Outback Class C to bring the costs down.
