bobkatmsu wrote:
Bumpyroad wrote:
from the OP it sounds like he barreled thru with the cruise control. only when the discussions seemed to turn did the brakes get mentioned.
bumpy
I think that your impression of me was the same as the officer, you both think I am a liar. You are both wrong, but that explain the ticket.
In the first post you said cruise control was on, you looked in the mirror and by then you were next to the cop. You did not say you stepped on the brake or turned off the cruise. If you can't move over, slow down. If you can't stop in the distance you can see, you are following to close.
