Sunnyjim245's avatar
Sunnyjim245
What size screw?
OK, got the instrument panel out but now I have a problem. The screws that hold it in were 8-32 which are too small to thread into the panel, 10-32 are too large. M4 is too small and M5x80 will only go in about a turn. What is this? Thanks!
  • OK. I think the original screw was a M4.5 X ? Anyhow I am going with what the previous owner had ie. an 8-32 with a nut. Consider this thread closed. Thanks for all the replies!
  • get a couple of zIP ties leave them unattached and put them in don't let them fall through the holes and then put in your screw more or less may be used
  • Use thes and the proper screw.
    https://www.summitracing.com/parts/rnb-45413?seid=srese2&cm_mmc=pla-msn-_-shopping-_-srese2-_-dorman
  • 10-32 tap. Buy the exact drill as called out by the tap at the same time.
  • I guess the holes are just wallowed out from what I'm reading. Just superglue toothpicks or matchsticks in the holes and use the 8X32. The screw will cut new threads.
  • Are you sure that it is not a sheet metal screw, with wide threads, instead of a machine screw?
  • Well, it's a Bounder so in my experience there's no metric in it.
    But if the hole had threads and stripped out, I guess you'd need to use a self taping screw the next bigger size?
