mike_brez
Sep 16, 2018Explorer
dougrainer wrote:mike brez wrote:
To do it correctly you need to lift front end off ground deflate bags then fill to desired pressure.
Check out page 10 HERE
Sorry, At no time does Chevy require you to LIFT the front end off the ground to air up the SUSPENSION IN COIL SPRING air bags. I don't get where you read this in your link. The main thing is, this is a REQUIRED part for Chevy P chassis with Chevy installed Air bags. It has to do with getting the front end to correct weight carrying capacity for the weight of the Motorhome. A LOT of people think they are ride suspension and quality of ride air bags. They are not. They must be in working order at correct air pressure for Ride handling and correct alignment. Doug
HERE on page 46
Screen shot
