Clay_L
Sep 17, 2018Explorer
For my P30 motor home - not my Sightseer, my owner’s manual gave the following ranges:
4,300 LB front suspensions = 10 psi to 50 psi
5,000 LB front suspensions = 40 psi to 50 psi
5,300 LB front suspensions = 50 psi to 80 psi
5,500 LB front suspensions = 60 psi to 100 psi
For the proper adjustment it says to inflate the air bags to the maximum pressure for your vehicle, load the motor home, park it on a level surface and then reduce the air pressure as needed to level the motor home but don’t reduce it below the minimum.
