Busskipper
Jan 14, 2016Explorer
midnightsadie wrote:
IF??? you put it away right? not much check fluids air in tires charge battery ,start her up.
BobR wrote:
I am assuming it is a gas engine at 33 feet. Start it up and run it. If it runs rough, add a fuel system cleaner such as SeaFoam. Make sure to run the genny with the fuel system cleaner as that will probably need it more than the engine fuel system.
Would agree -
12 months is really not that long - Fuel treat is critical IMHO,- but everything else should be fine.
I once bought a couple of 1961 B-61 Mack's - when they parked them they had a load of topsoil in the dump bed - we had to use a chainsaw to cut down the 6" tree growing in the back - added batteries, and air to the tires - drained fuel and started it up and drove it to the job - Had been parked for over 10 years, sold it 10 years later never missed a day.
While it may have been better to run it, it will likely not be an issue.
BOL,
