So how often do you guys & gals change your wheel hub oil oil? Frieghtliner says every two years. Cummins Bridgeway repair facility said, unless they're leaking don't worry about it. Not the answer I ...
Cunmmins is correct, if you did everything Freightliner wanted your annual maintenance cost would be over $3000 and the coach would not perform any differently.
