Roadpilot
Mar 29, 2014Explorer
We had an Overbilt lift on a 40' and then a 45' MH. When you My motorcycle weighed 800 pounds and the lift weighed about 200 pounds. That's 1000 pounds behind the rear axle, which adds quite a bit more then 1000 pounds to the rear axle and removes weight from the front axle.
The amount of weight added to the rear axle is a function of the wheel base of the MH compared to the distance the motorcycle and lift is behind the rear axle. Shorter wheelbases and longer distance to the motorcycle equal more weight on the rear axle and less on the front axle. Longer wheelbases are the reverse.
Blue Ox has a calculator on their site. It's at"
Blue Ox calculator
Blue Ox calculator
38,766 PostsLatest Activity: Jan 10, 2026
