Ivylog
Mar 29, 2014Explorer III
FGuard at 34-36' are you looking at a gasser? If so then I'd be looking for one with a 10K/1000 hitch. There is a reason on a 5K hitch for not putting more than 500 lbs on it or the back of the MH. Like Rpilot said you are looking at 1000 lbs which could put 1400 lbs on the rear axle and take 400 off the front. There are not many 35' gas MH with enough CCC or rear axle weight to do that.
Now if it's a DP there is a good chance it has a 10K hitch and enough CCC to handle the extra 1400 lbs.
38,766 PostsLatest Activity: Jan 10, 2026
