rgatijnet1
Dec 01, 2014Explorer III
Obviously you never want to exceed the maximum weight on either the front or rear axles. That said, they do make air bags that can be added to either the front or rear of most coaches to increase the load carrying capacity by 5000 pounds. That is more than enough to compensate for an additional 1000 pounds from a motorcycle. Again, the important thing to consider is if you have the extra 1000 pound capacity on your axle AFTER your coach is loaded for normal travel. Extra weight puts extra strain on your axle, shocks, and most importantly, your tires.
38,766 PostsLatest Activity: Jan 10, 2026
