Hi,
I'm not an expert by any measure on diesels, but I found this link on
Commonly Asked Questions About DEF.Wow...I just learned a ton of stuff about DEF! LOL
This is probably most relevant to your situation from that link:
"If stored between 10 and 90 deg F, shelf life will easily be one year. If the maximum temperature does not exceed approximately 75 deg F for an extended period of time, the shelf life will be two years."No "easy" answer, as it depends upon the temperature, but it looks like you could be nearing the expiration point if you have many days above 90 degrees F.
I hope this helps.
~Rick
