PghBob
Apr 29, 2016Explorer
Alas, as noted by Drew, the quality of a used RV depends more on how it was maintained and serviced, than anything else.
You want to get inside a potential rig and check for leaks. Look for discoloration around windows and doors, especially check the cab over window if the rig has one. Smell for mold and mildew. Check for soft spots.
Ask for proof the rig has regular service. Check the tires for date codes. RV/truck tires should be replaced about every 6 years no matter how good the tread looks. Find out if the rig was driven periodically or if it is a "driveway queen". It's not good for a RV to sit for long periods of time.
Check to see if the generator was maintained. Make sure all appliances work. Check the rig for delamination of the skin.
With respect to age, most would agree that an engine with modern fuel injection is much better than older engines with carbs.
Finally, there are some on the forum that recommend looking at rigs from rental companies since it is the companies vested interest to keep the units serviced and maintained.
Good Luck.
Good Luck.
38,778 PostsLatest Activity: Jun 05, 2026
