bsheet2
Aug 14, 2019Explorer
Success! Was able to weigh my MH today at the Flying J near Hempstead, Texas just off HYW 290. Was able to get the 4 quadrent weights. First weigh which give total and seperate weights for front and rear axals. Then reweigh ($2 more) by putting only the left side of the MH on the scales. This gave wheel weight for left side front and back. Then calculated the right side wheel weights by subtracting the left side wheel(s) from their axel weight.
Looks like I should use about 90 psi in all tires. And the right rear wheel wheel(s) can have almost 1000 lbs more weight on it than the left. Will probably only carry about 40 or 50 gallons of potable water when traveling to even things up a bit. The potable water tank is on the right side.
Thanks!
Thanks!
