mkguitar
Oct 24, 2015Explorer
generally:
many B's have the coach battery on the rt side in front of the rear axle
some have a genny aft of the rear axle
some have the propane in front of the rear bumper, between frame rails
or may be on the drivers side underneath
most have the dump valves on the left side...and the black water tank is under the toilet- with a very short run to the dump
some have the fresh water on the left side, in front of the black tank,kinda behind the driver's cab
and the grey tank may be on the rt side- kinda under the side door...with a 1.25 or 1.5 pipe to the dump valve.
this will vary with manufacturer/model etc
the location of the fill will give a clue without crawling under.
the idea is to get that weight balanced and low
mike
mike
38,766 PostsLatest Activity: Jan 10, 2026
