Matt_Colie
Aug 06, 2019Explorer II
Lamoz,
What you are describing is a common issue with all automatic transmissions. You did leave a big puddle of ATF somewhere and yes, you did probably damage some clutches and bands.
All transmissions collect water and it only leaves when the temperature makes it leave.
What happens when drivers are not aware of the situation is that the water that is in the transmission plan can accumulate to the point that if the ATF in the pan gets to near boiling point (that day at that altitude) it can boil. When it boils, it expands about 1600 times. That is plenty to blow all the remaining fluid out of the pan.
Matt
Matt
38,780 PostsLatest Activity: Jul 05, 2026
