MrWizard wrote:
I'm cashed strapped , don't have a $1000 too drop the 70+ gallon tank and install a new in tank pump
( there goes the stimulus check , IF it ever arrives )
I'm going to try blowing compressed air back thru the main fuel line,
I might even try a test, connecting to The generator pickup tube,
My biggest priority until now, was to get airlifts installed at the drive axle
There is a check valve in the in-tank fuel pump that helps hold fuel line pressure when the engine is turned off. You should not be able to blow back into the fuel tank through the engine fuel line. The generator fuel line is a totally different fuel pick up delivery system.
Richard
