- diplomatdonExplorerGCVWR= Total weight allowed of motorhome and towed vehicle
GVWR = Total weight allowed of motorhome
GAWR = Total weight allowed on front axle
GAWR = Total weight allowed on rear axle
What you need to know is the UVW or unloaded vehicle weight or dry weight. This is usually given in the same place as the other weights you supplied. However the only true way to find this out is to weight it empty. As for weight allowed to tow is dictated by both GCVWR and hitch rating, in your case probably 5000# - Dennis12ExplorerI drive truck and DOT drives me nuts on a monthly basis. Clean new trucks but still hassled. When you have the unit call DOT and tell them it's your neighbors that is out of town and you have the key and you want them to weight it because you know that they are overweight and you are concerned about their saftey.
- wallynmExplorerFor a guesmate take volume of all tanks in gallons and multiply by 8.5 plus you and all passengers weights. Then weight of all you required stuff you travel with. Now add it up and will be in the ball park. [kquote=Chowan]Ok, I know what the gcwr, gvwr, gawr f/r. but where do I find the overall wet weight of a MH so I can figure out how much I can put on board? Thanks for the help.
- usersmanualExplorer
Chowan wrote:
I am not saying we are going to purchase this rv, but this is what we looked at yesterday.
No matter what we get I need to know and understand how much I can load and pull with any DP.
Winnebago Solei.
GCWR 33,000
GVWR 27,910
GAWR 10,410
GAWR 17,500
So if I a understanding these numbers correctly I have approximately 5900 lb to play with which will have to include my toad?
No Your Gross is 27910 which has to include your cargo(people fuel,water,propane grocerys,clothes ,dishes etc etc)
The Overall weight combination is 33000 so your tow limit alone in theory is 5090lbs BUT if you pack less of a load(below allowable gross) then your tow capacity will increase - J-RoosterExplorerI did the overall weight in my Winnebago W-22 Chassis one time when I bought it new in 2004. I filled all tanks, except for gray and black tank and I didn't weigh with my toad. And my RV was overweight. I never bothered to weigh it again.
- ChowanExplorerI am not saying we are going to purchase this rv, but this is what we looked at yesterday.
Winnebago Solei.
GCWR 33,000
GVWR 27,910
GAWR 10,410
GAWR 17,500
So if I a understanding these numbers correctly I have approximately 5900 lb to play with which will have to include my toad? - pianotunaNomad IIIAfter doing a weight session I found that my frame was not over loaded but the driver's rear duals were. I went to a different size rim and higher capacity tires.
You are right to be cautious. I'd insist they do a proper weigh off.
Total
front
back
and each tire.
The fuel tank may be along the center line, so you can distribute the weight side to side, but the fresh water and waste tanks may not be. Make a calculation based on their capacity and add it *all* to which ever side they are on.
Add the "people weight", too. - tropical36Explorer
Chowan wrote:
That is a great suggestion, but here is my problem. I do not own the RV. I have all the gross rated numbers, but I don't have the real weight of the coach. How can one find out how much a coach weighs. And thus make some important calculations on what size toad I need to buy and how much stuff I can load and still be with in the rated limits. I don't want to buy something only to realize what I want to do with it cannot be done. Know what I mean. Thanks
The only real way, is to post the exact model of coach, you're interested in and wait for a knowledgeable like owner to chime in.
For instance, this recent new to us purchase had plenty of CCC posted in the closet with it's specs. so, I never gave it another thought and I was right, except for one small problem, as this rating wasn't evenly distributed. As it turned out and after moving in, we found that we were over on the rear by 160lbs, even though we were more that a ton to the good on the front. No biggie, I guess and even though I'm most sure all our tanks weren't full.
Now here's the real ringer and I've since found out on the American Coach forums that many of the larger coaches with a tag axle are grossly overloaded on the front with some spending thousands for a heavier axle. Can't sue FW as they were in chapter 7 for most of this and you can't blame Spartan for instance, as they didn't build the house on top.
As for GCWR, I usually just subtract the difference from the GVWR and assume the the rig will be loaded to the max. Even at this, you can be overweight with the toad, IMO, as long as the frame and tow equipment is inspected for strength and durability. I say this because it's all calculated for the steepest and longest grades, so it's never noticed for the most part. When it is noticed on those long 6%k or more grades, it's usually the transmission that suffers and there's a lot you can do with that, if it should become a constant problem. - IvylogExplorer IIIFor many years CCC (wet weight plus people) was required to be posted... usually hidden behind a cabinet door. Often that # was very small so now they only have to post NCC leaving you to try and figure out CCC and then if you can put any of your stuff in.
CCC did not substract the weight of dealer installed items. - darsben1ExplorerTHE GVWR would be the max weight of the unit (max wet weight) - dry weight = payload.
Look inside medicine cabinet or on a closet door somewhere.
If the motor home is not an orphan you might be able to call the manufacturer with the VIN and get the info you need.
38,763 PostsLatest Activity: Dec 05, 2025
