Bordercollie
Oct 28, 2014Explorer
When in doubt call the RV manufacturer if they're still in business, mention lack of info in generic owner's manual.
You should have a main drain spigot on outside of rig and two low point drain tubes fo hot and cold water lines that come out of the underside of the rig. There should be two small valve handles somewhere inside that need to be opened for low point drains to completely empty tank and lines. These must be fully closed completely for water system to pressurize and pump to work and shut off properly.
On our Tioga, valves are inconveniently located behind a panel on wall outside of restroom, hard to reach and hard to open and close.
