- mike_brezExplorerI just flip a switch for mine.
- robertbenitaExplorer2001 American Tradition drain is behind water bay door with all the plumbing stuff.
- John___AngelaExplorerWet bay, lower right hand side, two valves labeled low point drains. Open the cold and it will drain the tank.
- Carvin_MarvinExplorerMy 02 Southwind fresh water tank drain is under the coach by the frame rail near the steps. It is 3/4 pvc. Keep hunting
- BlackdiamondExplorerOn my 07' Discovery it was on the passenger side in the luggage bay about in the middle of the coach 1 or 2 doors to the left of the front slide, toward the top of the storage bay was a pvc 1/4 turn valve.
- fivejackieExplorerMy Hurricane has 2 metal rings on each side of the water pump. pulling both up drains the house system and the fresh tank.
- FormerBoaterExplorerOP, I forgot about the other 2 drain points on my 98 Eagle.
They are located in the cargo bays, passenger side in front of the rear wheels.
2 petcocks....
As I have never needed to winterize or drain I have only tested them once.
So, use the labeled drain valves in the water compartment +the two passenger side petcocks and you should be good to go. - sew0177ExplorerOur 2000 pace arrow had the fresh water tank in one of the bays with the valve in plain site at the bottom left corner.
- JimM68ExplorerOn the hope that "a Fleetwood is a Fleetwood" our 2000 pace arrow had the water tank above the framerails and driveshaft (yes I know yours is a DP)
There was a velcroed on fabric panel in the basement )actually behind the basement, since the basement storage came out with the slideout, I had to crawl under the slideout to get to it), which when peeled back, revealed the water tank and the mystery drain. - lanerdExplorer III have seen some mh's that the drain valve was located in a storage bin "behind" a small door. Everything in the bin was black so the door was hard to see. Had a small latch on top of the door and hinged on bottom.
Ron
