Trackrig
Jun 25, 2015Explorer II
I have a 2005 Fleetwood Excursion 39S so hopefully it's close to yours. The drain was very hard to find on mine also. All of the water and electrical connections are on the left side of the MH EXCEPT for the fresh water drain. It's on the right side a little over half way back. Get down to where you can see below the storage bins and it should be sticking down slightly below and behind the bins. Then the ball valve for it is up in the storage bin near the top of the bin.
Now this is the strange part. When I went to drain my tank to winterize it, my driveway has a very slight slant to it. The tank was over half full but would not drain so I kept doubting whether I'd found the right drain and valve or not. I finally used the levelers to get it perfectly level and then the tank started draining. I'd take a picture for you, but the MH is a long ways away.
Bill
Bill
