Hikerdogs
Mar 31, 2016Explorer
Mondooker wrote:
Effy what I hear you saying is they all use the same ford chassse, the same ford engine and drivetrain and most of the same suppliers! Would you go as far as to say "If you Buy a top end gasser, fix what needs fixing and they will all shake out about the same"?
They may be all built on the Ford F53 chassis, but Ford makes a number of these chassis in different weight classes and wheelbases. Look closely at the chassis specifications. While the wheelbases overlap in different weight classes many of the lighter chassis don't have the same amenities.
They all have the same engines and transmissions, but again the differential ratios change as the weight capacity increase.
Here's a link to the 2014 F53 brochure. If you look closely you'll see many differences between the 16,000 lb. capacity chassis and the 26,000 lb. capacity chassis.
http://www.fleet.ford.com/resources/ford/general/pdf/brochures/2014/Class_A_brochure-2014_LoRes.pdf
For the best handling and most cargo capacity try to get a motorhome built on the longest wheelbase, highest capacity chassis. As an example our 2013 Winnebago Adventurer is built on a 22,000 lb. chassis with a 228" wheelbase. The wheelbase is 57.1% of the overall chassis length, and the finished motorhome has a cargo capacity of 4036 lbs. The rule of thumb is that the wheelbase must be at least 52% of the overall length of the motorhome to have good handling in heavy traffic and poor weather conditions.
There are many motorhomes that do not meet the minimum 52% wheelbase guideline, or have as little as 800 lbs. of cargo capacity. Be sure to do your homework and pick a motorhome that has both an acceptable wheelbase ratio and sufficient carrying capacity to meet your needs.
38,782 PostsLatest Activity: Sep 02, 2026
