Just because they are pretty expensive, I was wondering, if you could only get and install one at a time, would you get the Helwig front or rear sway bar first? My coach is a 2006 E450 Super Duty /...
Yes you could, one at a time. You have to talk to someone and describe the symptoms . My new 450 was being pushed by bow waves and crosswinds and was wondering. I called Rvupgradesstore and was advised to install a rear track bar to stabilize the chassis to the rear axle which would correct my issue. It worked . They advised in my case, the sway bars would be overkill.
