- ksg5000Explorer IIIf convenience is what you want - permanent installed unit. Whether it's permanent or otherwise both you and your spouse/daughter are going to have to figure out how to use it.
- CiderExplorer
RedRollingRoadblock wrote:
I had a EMS-PT30C that I used for awhile. I secured it by running a cable lock through the locking tab and under the conduit to the power box. Most of the power boxes will close fully with the plug in it and if they had a hasp then I would put a small padlock on the box.
There was a lot of discussion on the fact that the plug to the camper would be exposed to the weather. I wasn't overly worried about that but I had a neighbor cover his with a trash bag. His theory was people might wonder why the bag was over it but likely wouldn't look and it would keep it dry. He liked my idea of the cable lock and used mine while I used my padlock. And I converted to his trash bag idea too. Besides in camping in the wet side of Oregon coudn't hurt.
X2 here on our unit. Same thing for me on a lock and key to secure to power post. Not that I don't trust people, but....Also chose a portable unit as I can use it on other units if I change without adding expense to new purchase. - RedRollingRoadbExplorerI had a EMS-PT30C that I used for awhile. I secured it by running a cable lock through the locking tab and under the conduit to the power box. Most of the power boxes will close fully with the plug in it and if they had a hasp then I would put a small padlock on the box.
There was a lot of discussion on the fact that the plug to the camper would be exposed to the weather. I wasn't overly worried about that but I had a neighbor cover his with a trash bag. His theory was people might wonder why the bag was over it but likely wouldn't look and it would keep it dry. He liked my idea of the cable lock and used mine while I used my padlock. And I converted to his trash bag idea too. Besides in camping in the wet side of Oregon coudn't hurt. - BumpyroadExplorerI have a portable SP and keep/use it while it was in the basement compartment of my class A and ran another cord from it out to the post. kept the compartment locked to avoid theft. same as MDKMDK does
bumpy - MDKMDKExplorerEach to his own, I guess.
I prefer to hide/conceal valuable ($233 + tax) items wherever possible, rather than display them for the five finger discount crew. Out of sight, out of mind. - LwiddisNomadBuild it in as Dick_B says.
- IAMICHABODExplorer IIIThe hard wired one Like This has a remote display so you can always see what is going on.
Will not walk away or be forgotten when leaving campsite like the plug in ones. Also easy to install,watch video in ad. - pianotunaNomad IIII prefer to use an autoformer and hybrid inverter/charger. I do check any shore power I plan to connect to before plugging in.
- rockhillmanorExplorer II
MDKMDK wrote:
I was planning on going with this one...
Surge Protector
I also have an extra 25 foot 30A power extension cord. I plan to plug the attached 30A power cord that comes with the motorhome into this unit, and use the extension cord to run from the surge protector inside the locked storage compartment to the campground power post. That way, I don't have to install or hard wire it, because it will be inside the locked compartment, and no one will know it's in there, unless they bream into it looking for something else of value.
That's a good one.
I would NOT add an extension cord to it though just to shove it back into the compartment.
Power surge protector plugs into pedestal,
plugged into your power cord.
Lock goes over protector coming from the pedestal.
There are a plethora of power surge protector "locks" available.
etrailer and camco sells them.
- MDKMDKExplorerI was planning on going with this one...
Surge Protector
38,769 PostsLatest Activity: Apr 04, 2026
