- glamisorbustExplorer IIMyself and two of my family members own DP's of the same vintage. All holiday rambler endeavor's 38' in length. Mine and my brother's are both '99 models with the 275HP cummins ISB. My dad's is the C7 CAT with 330HP. I have driven all three. All three perform great. The CAT does have slightly more noticeable power but not a heap more.
I like my cummins ISB. It has 660 LB/FT of torque. The power is more than adequate and pulls hills with ease, even heavily loaded. All of ours have the allison 3000 series 6 speed. Great transmissions!
Mine gets a hand calculated 9.63 MPG. This is combined flat, in the hills, and quite a bit of generator usage. My dad's with the C7 gets about 7 max. So yes, he has more power, but he gets less mileage.
Would I rather have the CAT? Not sure. I do like my fuel mileage better than his, and mine gets me where I need to go with ease. Pick the cleanest rig you can find and don't worry about the engine. - RayChezExplorer
mike brez wrote:
bobman wrote:
which is easier to service for a do it yourselfer
changing filters etc??
A side radiator makes things a whole lot easier.
About the only thing that it does make it easier to change would be the fan belts if it had any. The filters on mine are outside the rear radiator and just inside the hood (easy to change out).
The side radiators do not have a belt, they are hydraulic operated. So probably the only thing easier would be your alternator/ power steering pump and air conditioning serpentine belt. That I will say would be a lot easier to change then with the rear radiator.
The Cat engine is much better then the ISB Cummins, more torque. The Journey probably has the Cat engine. - RayChezExplorerGenerally Winnebago's have the AC/heat pump where the side radiator goes.
More expensive chassis has nothing to do with side radiators or larger engines. My friend in Florida has the exact coach I have and he has a side radiator and mine has the rear. Same chassis except mine has the Cat 3126 E and his has the ISB. - RayChezExplorer
wolfe10 wrote:
bobman wrote:
does the engine type determine if its a side radiator?
thanks
Generally speaking NO. Suspect the Freightliner chassis Winnebago used with either engine is REAR radiator.
Side radiators are found on more expensive chassis and generally those with larger engines. - wolfe10ExplorerFYI, the Caterpillar 7.2 will be between 275 and 330 HP, most with 860 lb ft of torque at 1,440. Perhaps 375HP is in a marine application with unlimited cooling, but not in an RV application.
- Gypsy1ExplorerThe Cummins ISB 5.9 Engine is a good engine and is generally combined with the Allison 2000MH trany. The ISB 275hp (5.9) is a flat land engine when in a coach. the Allison 2000MH tranny is limited to 600FP torque and Banks enhancement would exceed the limits of the tranny. Unless you are exclusively east coast flatlander like me, go with the 375hp Cat.
- wolfe10Explorer
thanks
Side radiators are found on more expensive chassis and generally those with larger engines. - RayChezExplorerI have a Cat 3126-E and filters are easy to change out, about the only thing that would be hard when ever it needs changing are the two fan belts. That is where the side radiator really helps having. But I have sixty thousand miles on my Cat engine and had it in for service at Freight liner Las Vegas and they told me the belts were still good. So I bought the two belts anyways to carry in case I have to change them out. Other then that I just changed the oil and oil filter. Fuel filter is very easy to change out since it is outside the radiator and just inside the hood. Air filter is not bad to change out.
Both engines will last you a long time, so go for the floor plan that fits you. - bobmanExplorerdoes the engine type determine if its a side radiator?
thanks - mike_brezExplorer
38,769 PostsLatest Activity: Apr 03, 2026
