Ivylog
Jan 12, 2014Explorer III
As a farm boy neither is a problem and yes I've had both plus travel trailers. A MH is easier as you can see what's in the way plus a rear camera and a DW. A toad is a non issue as it will go anywhere the MH will go and by the time the DW checks in it's unhooked. A TT will track better than a 5er because of the tail swing of the truck. Backing up I'd rate a MH the easiest because you can see better, a 5er second as you can jack knife it if needed and a TT last.
One trick in a tight turn with a long MH is to not try and make it in one turn. Wait too late to start the turn and then back up a little so you can complete the turn gets me into spots most can't. What about your toad you ask... click on "How I tow" below.
38,766 PostsLatest Activity: Jan 10, 2026
