bobphoenix
May 05, 2013Explorer
fredaevans wrote:Ivylog wrote:
For winter camping you need plenty of BTUs and plenty of fuel to convert to BTUs. Any coach that has a AquaHot will do well in the winter as it meets the above requirements. That said, there are still areas that require special attention... the ice make water line and the bay area where your dump valves and water lines are located will need some extra insulation or supplemental heat. Keeping some of the slides in will help too as most are not as well insulated as the rest of the MH.
Nailed it. The one 'extra' I do is put 100 watt light bulbs in some of the bays. Amazing how much heat they toss out ... but your electric bill will be ... don't ask.
Fred
A 100 watt light bulb at 24 hours a day is still cheaper than any 1500 watt heater that runs at ten minutes a time and shuts off and back on four times an hour... If you're lucky...
