SNOPRO711X
Mar 29, 2016Explorer
Your model number is GI0FSAXVY05. Letter I rather than number 1. There is no information on 8888 in the display in the tech sheet for this refrigerator. The thing to try is to shut the power off for 5 minutes and see if it resets. If the problem does not go away you will most likely need a new control. The HV control is located in the back of the refrigerator. You will have to move it out to get at the part. Part number is W10312695. It is not a real common part that you will find at most repair centers. It is available at the distribution level.
Good Luck
Good Luck
38,782 PostsLatest Activity: Sep 21, 2026
