Lwiddis
Jan 24, 2020Explorer II
Your budget may need some augumentation. WindyNation's 400 watt system is $720 but you'd also need two extra panels at a hundred each. With wire, connectors, DiCor etc. I believe you'd be over. IMO 400 battery amp hours would be on the low side too.
https://www.windynation.com/MPPT-Polycrystalline-Solar-Kits/Windy-Nation-Inc/WindyNation-WNI-400-Watt-4pcs-100W-Solar-Panel-Kit-Trakmax-MPPT-40-A-Solar-Charge-Controller/-/342?p=YzE9NDc=
38,766 PostsLatest Activity: Jan 10, 2026
