theoldwizard1
Jan 24, 2020Explorer II
mromberg wrote:
I'm trying to put together a 600 watt solar system for my soon to be purchased 2017 Class A Fleetwood Bounder. The coach is equipped with 4 100ah 12 volt batteries and a 2000 watt inverter. It also has a Samsung residential fridge.
This is a classic case of a RV manufacture trying to "save a buck" !
Four 6v golf cart batteries (size GC2) will give you about 420 AH of storage and well likely last longer and are the same price or less than 12V "dual purpose" batteries. AGM batteries are nice (zero maintenance) but expensive.
Personally, I would want an inverter/charger/auto transfer switch instead of a converter/charger and stand alone inverter. Maybe a bit more expensive, but easier to wire and MUCH easier to use !
If you plan to boondock a lot, a true DC refrigerator is more efficient than a residential unit. You probably will not find one as large and if you are on "shore power" most of the time you are camping, it does not matter.
38,766 PostsLatest Activity: Jan 10, 2026
