When the motorhome is plugged into shore power AND the engine is running, are the house batteries being charged by the engine alternator or by the converter off shore power? I ask because our slide...
It is a bit of a misconception that the charging system will charge one bank and then the other. I have not seen a system that does exactly that. Most will either charge all banks in parallel, or when the voltage level gets high enough on the bank being charged the voltage will be sensed and turn on the combining device.
