C_J1's avatar
C_J1
Who's in charge?
When the motorhome is plugged into shore power AND the engine is running, are the house batteries being charged by the engine alternator or by the converter off shore power?
I ask because our slide-out rooms run off the house side, not the chassis side (why Winnebago did that is a long story). Usually we have unplugged from shore power before we retract the slides. But today we happened to leave the shore power plugged in when we started the engine to retract the slides. They retracted ok, but I got a "low voltage" message on the slides' control panel. So I'm wondering if I shouldn't leave the shore power plugged in when deploying the slides.
We're pretty naïve about the electrical systems on the coach, so any input would be appreciated.
    house batterys are supposed to run the slides?? If u got a low voltage from simply running in yours slides I suggest the batterys are shot;; depending on the wiring system and relays/solinoids I suppose its possible the SP and the alternator could both charge the batterys
