Goldencrazy
Dec 07, 2013Explorer
Insulation on the hose may not be enough. Heat tape would be better. I would put some water in tank or use bottled until it warms up and turn off water at source, unhook hose and drain. Put light bulbs in your bays to add heat where any water or pipes are exposed. Amazing what a light bulb will do in a closed in small space. Plenty of propane to run the furnace and settle in. If you have enough snow shovel it around the motorhome so it is up to the bottom of the coach. it will be a great insulator for underside area. Assuming you didn't cut plywood to enclose the underside area.
ncrowley wrote:
We are living in our RV in Hurricane, Utah waiting for our house to be built. It will not be done until the middle of January so we will be here on Christmas.
I am sitting here watching the snow fall hard outside the coach. I am not sure what part of "We hardly ever see snow here" I misunderstood, but this is the second snow fall in a week here. The worst part will be the night temperatures. The forecast is for 1 degree on Sunday night. We have insulation on the hoses and we will drip the water but I am not sure that will be enough. Has anyone gone through these types of temps?
