ScottG
Aug 04, 2017Nomad
I'm using a Q100 directly off the regulated supply of my TT. You have to remove the Q's regulator to use it in this fashion.
Once you do remove it, your left with a nice 1/8" NPT thread that you can easily adapt to either a male quick disconnect or a propane hose.
I have the male ends attached to all my PP items (BBQ, Stove, Firepit) and 2 10' hoses. With theis combination I can put them just about anyplace and never have to carry a PP loose tank.
I used the fire pits regulator (because it had the highest flow) on the end of another hose that I can connect to a bulk cylinder. The other end of that hose has the same female QD.
I can run any of my PP items off either the bulk cyl. or the connection on the TT.
This has been wonderfully convenient.
38,781 PostsLatest Activity: Aug 12, 2026
