Mile_High
Aug 04, 2017Explorer
soren wrote:X2NAUTIQUE wrote:
soren,
I definitely opened it fully all at once before trying it.
so are you saying to just open the tank a little at a time and then light?
Or just open a little & then light?
Step one, grab a FULL one pound cylinder and screw it on. Now does the grille light and heat properly? If the answer is no, you have a defect in the grill, most likely a regulator issue. Now if you are hooked to your extend a stay, and it is having issues, after you successfully operated it on a one pound cylinder, you can blame something in the hose, fitting, tank etc....... One thing to look at is how full is the tank on the motorhome? Can you light up a gas burner on the stove and get a good flame? As for the OPD device we are discussing, it has nothing to do with a stationary tank in a motorhome. It is a safety valve installed in portable tanks.
The answer i got was yes, so I know I can't use my RV LP tap with the Weber unless I take the regulator off the Weber. I just stuck with 1lb cylinders.
