Executive45
Jan 07, 2016Explorer III
Have you checked your shocks.:h Since the noise is only heard while turning you most likely should raise the coach then start testing. If any parts of the front end are worn, or one of the shock housings are worn, they will feel tight while the coach is at rest. Put it on a hoist to relieve the pressure on the components, then start looking for slop....I think you'll find it that way...Dennis
