PastorCharlie
May 30, 2013Explorer
FIRE UP wrote:
stan909,
Well Sir, a few things here. First, based on at least quite a few years experience with fire trucks, Alloy wheels, mainly Alcoa's, are a tad stronger than the same wheel dimension of a steel counter part. They come in multiple finishes. If you're one of the types that likes the shiny way they look but, have no desire to "keep up that shine", then, they come with a clear coat that will keep them from oxidizing for the most part.
But, if you don't mind doing a bit of touch up every now and then, then you can get them with different finishes and, they're not clear coated so, over time, they will oxidize and get duller. But, if you do what I do, about every 3-4 months, sit down with some music on and, some polish, about an hour and a half later, you're back to a high luster.
Now, as far as weight is concerned, they are lighter but, not by very much. I pulled my rear duals off for some maintenance a while back and as usual, I have an outer alloy wheel and, a steel inner. Well, just for the heck of it, I thought I'd weigh each and see what the difference might be. My tires are Michelins and are the 255x80R22.5 versions. So, the alloy wheel/tire combo weighed in at , 144.2 lbs. and the steel tire/wheel combo weighed in at 167.4.
A whopping 23 lbs. difference, wow, big deal. Now, I'd bet my house that if you blindfolded someone, put them on a coach that had steel wheels all the way around and took them for a ride on whatever kind of test road you wanted, then came back, and put alloys on just the outside (as all coaches are equipped) and then took them for the same test drive on the same road, they'd never be able to tell the difference. That's a whopping 46 lbs. of unsprung weight. Doubt seriously it makes any real difference.
Anyway, it's a lot nicer looking wheel, in my opinion, if they're kept up in appearance. Just an opinion.
Scott
23X 4= 92. Also the hub caps on the steel wheels need to be factored in.
38,780 PostsLatest Activity: Aug 05, 2026
