1SG
May 30, 2013Explorer
I think weight is a factor for manufacturers to consider when putting a mh together. I have aluminum wheels installed when ordering a garbage truck because of the weight savings. I always calculate that an aluminum wheel is almost 25lbs lighter than steel so I can save 50lbs on the front axle, 50lbs on the tag and 100lbs on the drive axle so that is 200lbs more garbage I can haul which adds up over the years.
Aluminum wheels on a motorhome give you just that much more you can pack into the pantry.
Plus they look *****in.
38,780 PostsLatest Activity: Aug 05, 2026
