wbwood
Jan 07, 2015Explorer
tenbear wrote:wolfe10 wrote:
Oldme,
No, did not miss that. But, depending on how his coach is configured (where tanks are located-- how insulated they are) AND how cold it is for the first couple of days on the road, THAT will determine whether he needs to winterize.
X2 That time of year his first 2 stops can be cold. A lot depends on his rig. I wouldn't tell him he will be ok, then he hits a cold spell and damages his rig.
Agreed...heated facility doesn't tell you at what temperature and what if the heat stops? Especially if a facility away from you. Heated could mean 30 degrees or it could mean 100 degrees. If heat goes out, how long? Will the damage already be done before you are notified? Will you be notified? I would at least drain the tanks and put some pink stuff in the traps, at a minimum...Preferrably, I would pump some pink stuff through the lines as well.
38,770 PostsLatest Activity: Apr 12, 2026
