bshpilot wrote:
RCMAN46 wrote:
No need to manually check pressures if you have a TPMS.
In fact manually checking pressures may cause problems. Schrader valve sticking and resulting in a slow leak.
including flexing of the valve stems which can weaken them and cause them to split & leak (ask me how i know) ;)
TPMS systems work for me because i wasn't checking the tire pressures as much as i thought i should have (i wanted to check them before we departed for any trip and before we pulled out of a campground)....got busy, got lazy....didn't want to deal with dragging stuff out or the weather was bad (rain/cold) or the weather was good (too hot & sunny)
now i just turn the monitor on to check the tire pressure - nothing to do UNLESS i need to add air !
These solve the problem of broken extenders.
http://www.ryderfleetproducts.com/dill-eaton-9059-7/flexible-valve-stem-extension-7-p-c28-90597
